let me see youre duallys
88beast
pa
simple im thinking going dually
i want to see some standard cab dually trucks first
so post youre pics
thanks
HankHill
NY
FORDF250HDXLT
Maine & Oklahoma
F250HD full (front/rear) dually/budd conversion
so post youre pics
thanks
Complete Six Wheel Dually Conversion
Front & Rear Dually Wheel Adapters w/ 6 Matched set Accuride #28511 BUDD Style Rims (stock 2wd dually rims/salvage yard score)
Arrowcraft AA-4 Series Front Adapters (rear unknown/salvage yard score)
Pacific Dualies Stainless Steel Bolt-on Wheel Simulators #38-1608
Pacific Dualies Outer Wheel 180 Degree Valve Stem Extensions #18180
Pacific Dualies Inner Wheel 7 Inch Braided Stainless Steel Valve Stem Extensions #18000
LT 225/75/R16 (29.3X8.9)
w/Speedometer Recalibrated to 1065 conversion constant
Lowered Truck: 1.2" (primary objective for easier loading bed)
Effective Gear Ratio Change: 3.84:1 (secondary objective for better hauling performance)
;Sweet
almost forgot.if you want to take advantage of duals for weight.your going to want more than just 5 leafs.
i went:
F350 & F450 Super Duty Custom Rear Leaf Spring Packs
6 Main (two bottoms are thicker F-450 leafs)
3 Auxiliary w/ F-450 Auxiliary Perches (two custom short and 1 thicker top F-450 leaf)
93f250idi
strokin
cadiz ky
my old psd
[/IMG]
my ext cab
[/IMG]
88beast
pa
im liking this
i already have huge springs so good there
now i plan to pickup the drw axle and bed since my bed is shot now anyway
but i like the ttb i dont want a 60 its too expensive i got a lot sunk into my ttb and the ttb rides better
i was thinking of using stock aluminum drw rims in the rear and srw aluminums in the front
then run 285 75 16s on the front and 235 85 16s on the rear all mud terrains
kinda thinking like a new dumptruck
and the tires would work in 4x4 because od is so close
you all like the idea? or have criticism just let me know
Worstenemy453
King George, Va
If it has a flat bed or dump bed then its different, i like them, but stock looking, i cant stand a regular cab dually, im barely used to an extended cab dually. Maybe its just because i dont see many of them.
truckonfire
