Knocking 1989 7.3 idi. Help!
pelky350
Springfield, OR
When I timed by ear I was judging by how fast it started, starting from a point of I knew it was retarded and before the powerstroke rattle. Then had shop time it I was at 7'
Beefguy
Nebraska
I'm on R&D IDI performance website what is the difference in IP's RD2-80-RD2-110 and RD4-150 RD4-180?
Macrobb
North Idaho
Fueling capibility.
He rates his pumps in terms of number of CCs(per 1,000 strokes/injection cycles) at 2800 RPM(max power for an IDI).
Generally speaking:
A NA motor? Go with a 80CC pump. You won't need even that much to fuel it. HP wise, you won't get more than 125 at the wheels on a dyno.
Factory turbo motor or "stock" turbo kit - a stock 7.3 with Banks, Hypermax, ATS or Factory Ford turbo: Go with a 90 or 110 CC pump.
The 110CC pump will 'max out' the amount of air you can get from any of those turbos, but it's a very solid combination.
I don't have a 90CC pump to see exactly how much is 'lost' comparatively with the same setup.
Most turned-up 'stock' turbo setups with 'stock-ish' pumps make in the 180-200 HP at the wheels range.
A 110CC pump and said turbo will make a consistent 240-250 at the wheels - it's all the turbo can flow.
Anything bigger than 110CC pump is going to be for 'extreme modded' IDIs - this means headstuds(to keep the head gaskets from blowing), custom turbo(something bigger than any 'stock' turbo), and probably internal improvements as well, like a main bearing girdle and connecting rods, depending on the HP you are going for.
This is when you are looking at big $ and big HP numbers in the 300-450 range at the wheels. And, to my knowledge, nobody has done over 450 at the wheels with a modern IDI(There's a legend out there of a Hypermax motor making 1,000 at the wheels back in the 80s, but that wasn't reliable and was totally custom).
Girdle for mains not likely needed ...beefy bottom ends...for most anything except serious competition engine IMHO
tke395
