Kent Moore Timing an IDI engine
This is what the kent moore j33300 meter will look like when you rev to 2000 rpm and see the display readouts. You will have some flexing of the degrees of timing. Not to worry. What you want to see is what the reading is in degrees of timing at 2000 ron. When you shut down the engine the readings seen mean nothing on the meter.
http://www.youtube.com/watch?v=ANv48GEVuh0
Wel that really sucks Ken. Heres what I have made in viedos. Under my utube name The b24pilot these are whats on each viedo.
The ford engine viedo 002 pics of my wrench and the factory wrench
003 is a pic of the wrenches
004 pump removel trick
006 injecter opened and compared to G code
007 is differances in G & BB code pintles
008 is injecter pop testing
I hope these will get you to the correct utube viedos.
Bo17
