IP & Fuel Delivery
Spun4Fun
NC
LP as in lift pump
;Sweet Make sense . I am little slow tonight .. But i don't see that's possible specially with it pulling really strong up to 3200RPM's on 2nd gear ..I would think that i will do the same if it's bad LP
JLtoolman
Garner, NC
Still could be the lift pump. You are not burning as much fuel at 3200 in a lower gear, as you would be at 2600 in high gear pushing a lot of wind resistance. I love my Faucet lift pump. I would never go back to the mechanical.
AcIdBuRn02ZTS
Indiana
You could pressure test the pump.
Also, when was the last time you replaced the fuel filter?
Spun4Fun
NC
Last time was about 10k miles ago ,recently i had to empty the fuel filter and refitted due to other work i was doing , how much PSI should it putting out ? To confirm Do you hock up a Pressure gauge to the line coming from the LP to the filter housing .?
FORDF250HDXLT
Maine & Oklahoma
yeah.your just running out of steam and running worn out parts.time to call up CDI and get yourself some M@@SE! goods.that will cure all that ails her.;Really
the duralift e-pump as stated here for sure too.
duralift + moose ip + fresh injectors + timing set = much different truck.;)
Spun4Fun
NC
Yah last time i was visiting Family during x-mas i stopped at conestoga Diesel to say Hi ... What you just mentioned is exactly my shopping list but i need some green , Some benjies to make it happen
Spun4Fun
NC
You just plain ran out of HORSEPOWER.
I was waiting for you to lay down the hard truth about the 7.3 IDI ... I suspected that but wasn't convinced ( Specially not knowing the history of the IP beside it's OEM )
pwillis
