joe887766
1994 f250 single cab 4x4 with the IFS front "axle"
well started about three weeks ago now i wanted to do a simple job of change my trucks inner and outter tie rods on both sides. so i ordered the parts for it and removed all the old parts and went to match up the old parts with the new ones so i could set the length right (easiest way i could think of). well as i layed the parts out i seen i big problem real quick. not only was the old inner right hand side bar about an inch shorter its also a lot smaller diameter. And how the bend is, is way different to as can be seen in the pictures. so after i went to auto zone and ordered in a set and they are different too but not the same as the first set i bought. im not sure on what to do since its not like my truck drives bad or wears tires or anything. so i cant see that bar being bent that bad, and to me it still doesn't make since why all the diameters are smaller them mine. i have looked on F350s too hoping they might be bigger. any ideas?
