Injector Help!
zigzkidz
Butler, PA
Ok i was taking my injectors out and just the top came off so the nozzle is still in the head. How can i get it out?!?
hesutton
The Anti-Anderson
Bowling Green, KY
PB blaster and grind the threads off (this assumes you will be replacing the injector) the injector that hold it into the head. The threads that hold the lower portion of the nozzle should not be removed. That way, you can just turn the injector clockwise in its bore until it is loose enough for removal.
Be sure to use anti-sieze and new return lines/caps when reinstalling the injectors.
Heath
HammerDown
Glenolden Pa
I don't know the assembly of a injector...does the bottom section screw onto the top half that screws into the head?
Anyone have a breakdown pic of one?
