PB blaster and grind the threads off (this assumes you will be replacing the injector) the injector that hold it into the head. The threads that hold the lower portion of the nozzle should not be removed. That way, you can just turn the injector clockwise in its bore until it is loose enough for removal.
Be sure to use anti-sieze and new return lines/caps when reinstalling the injectors.
Heath
