Dirtleg
This is my first post here. I bought my 93 f350 4x4 2 days ago. I have been looking for this type of truck for a while now and happened to find this on my trip to Houston this week. Price was right and the truck is reasonably clean. I wish I had found this site prior to my purchase but am really happy with the truck so far anyway. It is my first diesel and I've much to learn about proper care and maintenance.
Well just wanted to say hello and also let ya'll know that I am really glad to have found this website. Very good information and tech pages here. On to my questions.
Truck starts and runs perfectly when cold but won't fire when hot. I found the tech info on this and it most likely is the injection pump. I can get it to fire and run if I spray starting fluid down the throttle body. I really don't like doing this but have had to as being stuck was not an option. This evening I am embarking on a trip from Houston Tx, where I bought the truck, to Atlanta, and then back to Virginia.
Will the injection pump just up and die on me or am I just looking at hard warm starts until I repair the problem. This I can do once I'm home. Also, the info stated that the pump is heat soaking. Am I correct about it being a vaporlock issue?
Looking for opinions, advice, quick fixes, or any other information that will help keep me going.
Fuel Filter. Is there a proper technique to follow when changing it? Do I have to bleed the air out of the system after and if so how do I do that?
I went ahead and changed the oil and accessory drive belt yesterday and bought a fuel filter but am too uninformed to attempt to install it yet. When I get home I will flush and replace the coolant. I read about cavitation so SCA'a will also become a maintenance priority. I intend to flush the brake system once home.
What are the primary issues with and care for the E4OD? It's been my experience with Ford automatics that if they haven't been properly serviced since new you are better off not touching them. They tend to fail soon after servicing.
If you know of any other issues I should be wary of please mention them.
Thanks. Greg
Thanks. Greg
