in need of some 4X4 parts
94f450sd
somewhere,ma
i dont have a ton of money so go easy on me,please.i may also have something you need so maybe we can do some tradeing.
i need the adapter housing to go between tranny and transfer case and output shaft on an E4OD,the 4X4 shifter and linkage for E4OD.i also need the rear blocks to level the truck out.im not sure what size i need or if i need them yet.
this is the transfer case i am useing
sle2115
NRA LIFE MEMBER
Southeast Ohio
I think I still have a set of blocks around here from my axle swap. I will try to look tomorrow. If I have them, they are yours.
Scott
94f450sd
somewhere,ma
thanx scott.i think my truck has 3" rear springs,not sure though.you should have your wireing in 2-3 days.
john that wont work on the E4OD,but thanx anyways
sle2115
NRA LIFE MEMBER
Southeast Ohio
The spacers I would have would be out of my 87, which was 3 inch front/rear springs. The 85 axle used a 2 1/2 stack and I used the spacers for the 2 1/2 with it. So, if I have them, they would be 3 inch.
I haven't had a chance to look though, wife is having some medical problems that the doctors can't figure out. Just got in from the ER for about the 5th time. Nothing like coming home at 3:30 AM sober...boy I need a drink!
94f450sd
somewhere,ma
take your time.like i said im not sure if im gonna need them or not.i have a 94 F350 that all my parts are comeing from but it had the small springs.i also have a 92 F250,but havent checked the spring size in it yet.
Studebaker62
