FordGuy100
That my AC has a leak. I'm thinking the compressor as the front (where the clutch is) is all oily. Went to a co-workers house and drew down the system. Had to leave as he had to go, so I drove back home, and started filling it up.
First thing I noticed, no refrigerant wanted to go in. Was having a super hard time getting the thing to accept refrigerant. But just a couple minutes ago I got it to where the evap was icing up when the pump kicked on (well the pump would kick on, then off, and about a sec later ice would form).
I'm planning on pickup up a manifold gauge set as I really need to know when its kicking on and off.
I adjusted the do-hicky screw that adjusts the pressure. I had it to where it would either switch off and on every other second, or if I turned it enough, it would hold it on for a fairly long time, and the evap would ice. Do I need to let some R134a out, and adjust it to where it holds it on longer? If I do that now it will just ice up.
JK
