My understanding is the diesel ZF5 is a close ratio and the gas ZF5 is a wide ratio. I've owned and driven several small block and big block ZF5s but never a diesel ZF5. I recall with a 302 making it scream in every gear to get anywhere. I have a 460 ZF5 with a tailhousing sans mounts (last relic of my annual ZF5 replacements). Have a diesel ZF5 with good cases. I intend to do new bearings, syncros, and anything else the diesel ZF5 needs to put behind my 6.9 turbo.
I've been told I drive my 460 like a diesel, usually shifting by 2000RPM as torque is plentiful off idle. Ironically with the C6 I let the IDI scream as it's the only way it'll get moving. IDI seems to make about the same power everywhere, which is not much. Thinking wide ratio may help a bit towing with lower ratio first to get moving. Not sure how the other gears compare. Thoughts?
