IDI project questions
88 Ford
San Diego, CA
WOW! That is going to be a cool project. The 088 is going to feed the supercharger correct? Studs sound like a good idea if you've not already done so.;Sweet
Heath
I was gonna keep boost pretty low for now to test the setup and due to the fact at this point I can't afford studs. Lol. It'll probably be around 15 psi to start. And ya the 088 will feed the SC. I want an 088 due to the exhaust housing size being bigger cus of no waste gate and also due to the fact that it sits straight behind where my mount will be with little to no modifications to my mount. - also have a Moose Pump already and DPS injectors, so my fuel should be good to go. Now I just need that boost.
tke395
