IDI project questions
88 Ford
San Diego, CA
So does anybody have any info on the ATS 088 turbo? Like how far behind the intake manifold is it and what are the size of the up pipes?
seawalkersee
It needs a turbo...
KCMO
Dunno about that turbo, but the selonoid for that is vacuum activated. I would try to find an "on/off" style and go from there. However, it may not make enough to make a difference. If you can't find one, try it without and proove me wrong.
SWS
88 Ford
San Diego, CA
How would want it closed most of the time except at idle right? How would I go about setting up the on/off switch so that it is set to be closed when not idling anymore?
rhkcommander
Oregon
If you want to get a little creative it wouldn't be hard to make a simple computer based off a tach signal, if the rpm falls under 900 relay off otherwise relay on
itsacrazyasian
residentcrazyasian
boca raton, fl
Don't worry about the stupid little vacuum can on the side. Its for GASSER cars/trucks with a throttle body. Its meant under vacuum conditions to bypass the blower to reduce HP consumption. apply positive manifold pressure as you start to spin the blower faster and open up the throttle body it'll press it closed. Our motors are big air pumps anyway.
I have 3/4 of the pulley with the belt wrapped and i can still blow the belts off the car if i'm not careful. Between my mod motor 5.4 and my buddy's whipple powered 4.6 3v we change serpentine belts every 6-8k depending on how hard we are on the cars. These things slip when you start to spin them up and again on the spin down. When i downshift hard i can usually hear the belt squeal. Same thing with my buddy's mustang. So if you are going to do a v belt, gonna need more than 1 or 2.
I have an ats088. i can take pics and measure for you tommorow if you like.
88 Ford
San Diego, CA
What do you suggest I do with the vacuum side thing in your opinion?
Also I would really appreciate if you could measure the 088 for me. That would be awesome!
rhkcommander
Oregon
Cool idea but a lil hard for my taste. Haha
Yeah most guys here don't like to tinker with that sort of stuff :D. Maybe make a manual fast idle switch, and have that also hook up to the blower. No more automated stuff...
turn the truck on and it would idle slow but no boost, flip the switch to pick up some rpms and boost :dunno. Trying to think of how to do the KISS method now.
Starter might be fine with turning the super boosting though :dunno. I knew a guy who had his truck parked using a gear and the starter solenoid or somewhere along the trigger wire malfunctioned and his truck drove a short length and started trying to (or did... forgetful) climb up a neighbors' cars hood :rotflmao
88 Ford
San Diego, CA
:rotflmao :rotflmao Ya that would be pretty crazy!
You think a hobbs switch would work? And if so how would I need to set it up? Maybe that's the on/off switch SWS was talking about? :dunno But anyway maybe I'm getting too technical. It just might be easiest to but the stock part back on and make it function like it was built to. Idk only way to know is to test it out.
rhkcommander
Oregon
Hobbs could work probably, I was thinking about it too earlier when I posted but forgot the name LOL. I'd go that route if you could make it work, to be automated and all
88 Ford
San Diego, CA
Well I'll definitely see what happens and what is easiest. Haha
seawalkersee
It needs a turbo...
KCMO
Yeah, run the TPS to a relay. When it gets to a certain voltage, it will close the relay and activate the selonoid and close the valve. See...simple.
SWS
hesutton
The Anti-Anderson
Bowling Green, KY
WOW! That is going to be a cool project. The 088 is going to feed the supercharger correct? Studs sound like a good idea if you've not already done so.;Sweet
Heath
tke395
