Ok , well been quite a while since my last post or update.
Here goes........
Bronco is still mobile under 5.0
Good news!
1. Acquired a known reasonable running 7.3 engine for a mule engine (allows rebuild of Turbo engine, and Turbo) I work with this fellow, it's his old Tow truck engine he kept when converted to 7.3 PS
2. May have a ZF from an F450 (still negotiating) Same tow truck...
3. I have my D70 rear, Cadillac rear calipers coming, need adapter brackets and rotors
4. Have HD coil springs for front (0 Lift at this time) looking into springs for newer F250-450 for lift
5. At this point have complete parts for conversion except 1 single item I NEED a 87-90 Rad support for diesel engine Mike may have a line on one too !
For me to install turbo....Need turbo mount/oil return, cast up-pipe to turbo, X-over pipe (Can likely be fabbed at exhaust shop), and a rebuild of turbo too. Will find an intercooler and install prior to conversion so it's in n ready for use even without Turbo in!
Will do SAS convert to D44 from F150 with spindles rotors n calipers from D44 Chev to make 8 bolt front (D60 comes later) to match rear D70
Tow operator is helping me out huge!!! Thanks MIKE!!!
Mike has been instrumental in helping me and encouraging me (refocus) on this project....He calls the Bronco the warehouse ***** (its full of parts he gives me and lotsa tools), I call it the TUG;p cause I was pulling his forklift loaded with up to two cars all over his muddy property, he would get stuck, I would bail him out...this went on for near 3 days while he was moving some cars for processing, lol it was a blast!
He has given me lots and lots of parts in trade for work, now I have a 3G 130 amp alternator to install and will be installing a Saginaw PS pump with remote reservoir too, so I can use my hydro-boost along with a hydraulic ram assist for steering!
We are even looking at a second Bronco to do a Frame off conversion with body lift, just happens to be one locally to view..will update asap.
Lots happening over last several months
# 1 NO LONGER WITH WARRIORMAMA....moved on have new G/F ROSE oh ya sweetie! Just adorable, and so much fun!
# 2 at this point no longer working in Ft. McMurray either
# 3 Working with Mike (Tow operator) looks very promising for future, lots going on.
Anyway, will keep ya all updated as it proceeds.
Here goes........
Good news!
