I have a quick question
Exekiel69
Good, Thank You. The engine is in a 1999 international truck but I wondered if it was the same engine.
apextrans
What Log Book????
Fallston, MD
I think the heads are interchangable. When I went thru my motor troubles & found out I needed heads, I found out after I bought reman heads from Ford that the IH heads would have worked & were almost half the price. The valve covers had a different bolt configuration IIRC. I remember 'cause I was -cuss about the money.
94f450sd
somewhere,ma
the heads are interchangeable.only difference is the bolts on the intakes.they changed the number of bolts holding the intakes on once or twice.the intakes also have a slight difference.99-up had bigger intakes than the 94-97s did
JLDickmon
Bo Duke
49041. OU812?
leave it to Ford.. take a good engine and muck it up by replacing some parts with proprietary ones...
bitter?
I'm not bitter...
$900 for an IDM and an injector...
but I'm not bitter...
a little salty maybe...
geonc
SPIDER BAIT
NECKVILLE North Carolina
bitter?
I'm not bitter...
They did at least kiss ya right....or by you dinner :eek: :D
I know the intakes and water pump are different....many have used the T44E water pump due to it's built in coolant filter hsg.
