i have a problem someone please help
mark7.3idi
wauseon oh
My 88 f250 is leaking oil out of the rear of the motor at the top what could it be a head leeking or ?????????? i dont know please help.
EMD_DRIVER
Say what?!?!
Beaufort, SC
It sounds like it could be coming from the oil pressure sending unit. It is mounted at the top of the engine, in the back. Maybe it's time for a new one.
EMD_DRIVER
Say what?!?!
Beaufort, SC
Is the gauge working? If it's a mechanical gauge, could the line be leaking? When my 93 was leaking oil from the top side of the engine, it turned out to be my WMO leaking from a broken return line cap.
LCAM-01XA
my very own hell
Are you sure it's actually oil? Could be diesel fuel washing off old oil and dirt deposits, and the source is actually the return lines circuit like in Gary's case.
Greenie
Mine leaked from the nipple between the oil pressure sender and the engine. An easy fix if that's the problem.
GenLightening
Yeah, it's a CHEVY!
Pukalani, Hawaii
Since yor profile isn't completely filled out on your truck I have to ask, do you have a turbo? If so, it may be from the drain hose or grommet. If not, clean everything really well, then run it and see where it's coming from.
Get the back of the engine real clean and dry. Then you will be able to see where the leak is coming from. Make sure the valley pan drain is open and working.
sootman73
Wauseon, OH
yes there is oil on his firewall. not much if any getting to the ground. a guy told him it was a headgasket. but no oil in coolant and no water in oil. maybe cdr valve on back of intake?
tractorman86
Buckeye, AZ
i would bet on either the CDR or the grommet for it.
sootman73
Wauseon, OH
thats kinda what i was thinking too. course i wasn't sure. then we pulled the motor out of this other truck and it showed similar oil leaks but not from the head. i said something about valley pan gasket.
Gerhard
