yARIC008
Drives really slow
As far as I know the original proportioning valve was in that spacer dealie at the master cylinder. I installed a slightly larger master cylinder that didn’t have that spacer. I installed a new proportioning valve on a custom bracket right next to the new master cylinder. The original bore size of my master cylinder was 1-1/8” and I replaced it with 1-1/4”. Pedal has less travel and works well with the hydroboost, however I might change it to a 1-3/16” soon to give a little more hydralic pressure.Did you delete the OEM proportioning valve since all 4 wheels are disk?
