93turbo_animal
heck yeah I'd cut the pin off your old one and weld a new one on in the right place. If clearence is an issue and yo don't have room for the weld bead drill a hole thru the arm and weld the pin from the other side
Mel,
In your other post on the aftermarket hydro system they had a machined piece that looks like it's meant to compensate for the offset. Maybe they sell them seperately and could shoot you one out quick so you could use your old pedal
if you got to moving the pin i would drill it through then weld it from the backside. it would be much stronger this way letting the metal in the pedal support the pin mosly instead of having the weld in a shear-torque transferring the stress to the pedal if you just welded it flat on.
