Hvac help!!
Caden
Cascade locks Oregon
So I have a 1991 f250 7.3 and the blower motor stopped working a few months back by that time I had already had to replace a couple fuses but I went to replace the fuse thinking it would fix it and the fuse wasn’t blown I took it out then put it back in and it started working on all speeds for a few days and now it won’t work again if anyone has had this problem please help me out i would appreciate it
Oldfrogdiving
Melbourne
Maybe check the ground on the blower? I dont have A/C but my heater quit blowing it was a loose corroded connection and fairly gunked up ground.
chillman88
Central NY
Is it not working at all or only working on high?
If you only have high it's a bad blower resistor.
lotzagoodstuff
Carmel, IN
+1 on what chillman said above. If it was me,I’d pull the resistor out of the firewall and inspect it, because it’s free and it’s not that time consuming.
tke395
