https://www.ruffstuffspecialties.com/catalog/R2055.html reviews?
Simmonscoating
millersville md
So why did they ever go away from 4 wheel drums?........
Because of the heat generated on the front breaks can cause the breaks to fade out it was a problem with older vehicles. 70% of all breaking are done by your front breaks unless you are caring a lot of weight in the bed then your back breaks play a bigger roll.
Simmonscoating
millersville md
Here is some data a friend of mine has a 93 f350 dully he did a rear disc set up on his rig, I have a 94 f350 dully mine is original drum. we both work he hell out of our trucks and i drive both, I personally don't see any difference in stopping power. neither truck is running hydro boost but my drums are in good working order. Nothing wrong with the disc set up, but if you have other issues its just going to transfer the problems to your disc set up. In summery drums in good working order vs disc the cost and time to do it don't expect a big improvement in stopping. Hydroboost is prob the best upgraded to get line pressure up and improve overall performance.
sjwelds
Central KS
Brakes.
pwillis
