how to install thermostat
dyoung14
Is getting worn out
spencer,tn
Which way do you put the thermostat in? i didnt pay attention when i pulled it out, do the spring go down in the block or up in the water neck?
93f250idi
strokin
cadiz ky
spring goes inside the block on gassers. the pointy part goes towards water neck lol. that is on a gasser dk about a diesel
88beast
pa
the pointy part goes up the cylinder goes down its very easy just dont over silicone the bypass port
typ4
Newberg,OR
silicone is a bad sealer there anyway, it can shear from the thermal differences and cause leaks, a smear of liquid permatex or hylomar is the best.
Oh and the pellet, copper colored thing, goes to the hot water an all engines.
dyoung14
Is getting worn out
spencer,tn
i just used the gasket didnt use any other sealant, i put the springs in the block did i do wrong? i done it before i came and checked this thread so do i need to go back and change it or am i ok?
