tbirdfiend281
a 7.3 truck isnt a mustang, it wont have over-rev codes in it...
the p1000 could mean to many things to tell, the kam codes can occasionaly be set when the stuff is taken off the truck, but that is hit or miss again.
a 7.3 is not the same kind of system as a 6.0 it will not have an overboost code from having more boost from a chip, the tell tail sighns are usually related to having some sort of ICP code in there from the chip running more high pressure oil, witch in turn runs more fuel, witch in turn gains you that 150hp you just dialed into, on a 7.3 this will not hurt the truck.
what problem did that truck have at 9800 miles that made your dealership believe it was related to the pda programmer?
