One thing to consider with the pedal assemblies is that the F450 hydroboost has a fairly short pushrod for the pedal so when you put it in a vacuum-assisted truck the pedal pin being lower results in the pushrod being angled down, which throws the whole geometry off and really screws up the pedal feel - my pushrod is 2-1/2" longer to begin with (makes for less angular deflection within the pedal travel), and I also have the whole booster tilted backwards right at the firewall so the pushrod is pointing straight at the pedal pin from the get-go, so I don't have that issue.
Your years for hydroboost use sound about right. Chevyboy_0, the GM boosters are not a direct bolt-in for our trucks, they are for GM fullsize trucks but Fords have a very different dimensions - I had to space the booster out of the firewall by over 2", good thing is this way I was able to adjust my pedal height to where it's more comfortable for my foot, but still it's not as easy as simply pulling the vacuum stuff out and putting the hydro stuff in. F450 boosters are a direct bolt-in tho, it's good to have the pedal pin higher like Tknomaj corrected the geometry, but they certainly will work with the factory pin location too and will still be better than the vacuum stuff.
