Diesel JD
The 289/551 is nothing to write home about at the crank. If that were at the wheels that would be pretty snappy. You said at the wheel, I assumed you meant flywheel HP if not my mistake that's as good as the stock and lightly modified 7.3 PSD. If you meant at he flywheel then figure a 30% parasitic loss in the drivetrain so 202/386 still really good but I bet you can easily throw down those numbers all day with a Moose or similar pump, Moose Misters, an intercooler and any turbo. Travis was there with the E and Darrin was there pre Cummins conversion with a 7.3 turbo IDI. I wonder what pump is on that 7.3 marine diesel. If that turns the opposite way that means it can use the GM DS4(electric/mechanic) or all mechanical DB4 for 6.5 marinized diesels.
