Hit a Snag
Cincinnati Guy
Cincinnati, Ohio
I got the motor all the freaking together and now when you turn it over it will only turn about 1/4 way either direction. I Have taken out glow plugs, injectors, took of oil pump, manifolds, injector pump, fuel pump, and it still will not turn over.
I have had the front, fear seal replaced, have not had heads off, I have taken the valve covers off to look for obstruction..
I am thinking a wrong bolt somewhere maybe or something got dropped somewhere, I dont want to take the heads off but I may have to....
Would a missing crush washer cause this?
Anyone have tips for me.
GenLightening
Yeah, it's a CHEVY!
Pukalani, Hawaii
Are the pushrods and rockers in place? Did you have the timing gears apart? Sounds like the crank and cam aren't in time and a piston is touching a valve. Oh, are the water pump bolts all in the correct positions? Seem to recall if one of the longer ones is in the wrong place it can hit the timing gears.
Cincinnati Guy
Cincinnati, Ohio
I have the whole front of the motor off. We never removed the camgear, or crankgear. Before I replaced some things here and there it would turn over, but now its not. I am stumped along with the ones helping me.
Cincinnati Guy
Cincinnati, Ohio
Flywheel is off it. Its just confusing cause it once turned over until we started putting it back together. I hope I dont need to take the heads off.
dyoung14
Is getting worn out
spencer,tn
just think of what all you have changed, then start pulling it off one peice at a time, after each piece, try turning the engine, sooner or later you will find out what you done wrong
87crewdually
Southern Nj.
My money is on the cumbustion cup dropped out of one of the heads and is the cylinder. Seems like you checked everything else. I can see this happening because I know mine were loose.
The Warden
MiB Impersonator
Fog Bless Pacifica (CA)
Unless it fell out while he was in the process of mounting the cylinder heads, I don't think that's possible. I don't have a better picture, unfortunately, but if you look at this pic:
the precombustion chambers overlap the edge of the cylinder to the point where about 1/2 of the chamber's held in place by the block surface. You can see a corresponding spot on the head gasket...I don't think it's physically possible for the precup to fall into the cylinder unless it's in pieces.
My guess is the water pump bolts...
RLDSL
Diesel fuel abuser
Arkansas
How long was it on the stand? WEre there any openings left large enough for a small rodent to climb in there?
