History on the truck
Joeharvey83
San Antonio TX
Hi everyone I'm joe. I have a 1983 f250 that originally had a 6.9 and a c6. I bought the truck when I was 17 for some ranch work I was doing. Quickly found that it was no race truck but was hood for stuff on the ranch. I met Wes at classic diesel designs and I realized i wanted to make the truck for fun so i ended up buying a junk yard na 7.3 and rebuilding it and making some power but that lasted about 2 months before I broke a rod and bend the crank and bent a push rod and stamped 2 pistons. I now work at classic diesel designs and I'm building a 94 7.3 t build. The motor is in amazing condition has completely rebuilt heads shimmed comp valve springs powerstroke 1st compression and oil ring , arp head studs, stage 1 injectors, a 180cc injection pump, and the CDD to4z 67m turbo. I hope to break the current record at 466 and bump it up to 500 or 550.
chillman88
Central NY
I'm excited too! Definitely looking forward to it!
So why this as opposed to the total seal 2nd ring that is available for the IDI?
Wes, what's that ring in the picture. Cam ring for the IP?
Tyler9828
