high egt low mpg
nj_m715
government's finest
NE of Atlanta
96 psd started acting up. seems to run ok but I noticed increased egt and high fuel consumption
I estimate that I used about 5 gals to drive 32 miles, I normally get 17.5
normal driving empty truck with rolling hills egt are 400-800 now I see 400-1050
new back pressure tube, cleaned sensor last yr
ebpv delete
hydra - runs the same with or without tunes
napa filter
3" dp 4" diamond exhaust
all mods are a yr old or more
no codes on car gauge pro
my hands are full for the next couple weeks so I don't have much time to tinker
can you think of any relatively simple things to check before I send it to the shop?
stuck injector dumping fuel too much fuel?
I might have time to buzz test tomorrow, not sure if it would show anything
thanks
nj_m715
government's finest
NE of Atlanta
lol, this is why I posted on the IDI side when I was stranded out of state and looking for a fuel bowl.
talked to my shop, he's busy for 2 weeks, said it sounded like exhaust/ boost leak
just installed a boost gauge to see, wanted to install one anyway. either the gauge is bad or I'm making no boost
gauge reads from -1 to +1 psi
time for soapy water I guess
greenskeeper
PA
15 psi or so is stock boost at WOT
Assuming you don't have an intercooler being an OBS, sounds like you've got an air blockage going into the turbo (filter?) or blockage in the exhaust (EBPV?)
nj_m715
government's finest
NE of Atlanta
I built a pressure adapter, aired up to 15-20psi, found no obvious leaks but my pos boost gauge read 3 psi so my boost might be fine
I have napa filter, intake side looks ok, ebpv deleted last year
I'm no modern computerized mechanic, but I'd still guess injector leaking fuel, idk?
all that extra fuel is going somewhere, it's not on the ground, its not in the crankcase. I think it's going out the exhaust but theres no excess smoke
greenskeeper
PA
Finish the tank and calculate actual fuel mileage. You really need at least 3 tanks to get a good average. Maybe the selector valve is failing and its dumping fuel back into the unused tank?
nj_m715
government's finest
NE of Atlanta
I don't drive that, truck sits a week or more at a time. would take a year or more for 3 tanks
I'm almost down to 1/3 I haven't refilled since the fall that's why I have to estimate by the gauge
I calculated my 17.5 mpg on a rare road trip last year
but the unused tank is normally topped off so it should overflow quickly
greenskeeper
PA
So you're trying to compare fuel mileage on a road trip to very short trips, separated by weeks? 10 mpg wouldn't be out of the ordinary for short trips.
Why worry about fuel mileage if you drive so little?
Did a varmint make a nest in your intake or exhaust, blocking flow and increasing the EGTs?
You need to get out and DRIVE your truck, then see what the mpgs are before throwing parts at it, chances are nothing is wrong especially if there is no CEL.
nj_m715
government's finest
NE of Atlanta
no, I'm just using the info I have available
I estimate closer to 5mpg, but whatever.
I live in the country, it's pretty much all highway driving. there's not much difference going 55 on a county highway or 65 on an interstate.
there's not much stop and go around here
I wouldn't expect exactly the same mileage but suddenly there is a noticeable difference
I'm not but something it wrong with the truck, If I was worried about mileage I would buy a vw rabbit
maybe, would that smash mpg into the ground?
thanks for the advice, I checked for codes, did a boost leak test and asked for ideas. I don't throw parts at problems I prefer trouble shooting to parts changing
greenskeeper
PA
Ok, so drive enough to calculate the actual mileage and go from there instead if estimating fuel consumption.
Maybe the pump clicked off at your last fillup weeks ago and you never started with a full tank?
Somebody stealing fuel from your truck?
nj_m715
government's finest
NE of Atlanta
I'm from nj, I got locking fuel caps. and if someone can steal fuel while I'm moving down the road at 55, then they deserve to have it
I didn't start with a full tank, I watched the needle drop from exactly half to about 3/8th while only driving 30 miles
I have a 39g tank I never see the needle move in 30 miles
needle movement isn't an exact science but I never observed this behavior before, it's obvious something is going
greenskeeper
PA
Ok I give up...where’s the hidden camera on this joke of a thread?
nj_m715
government's finest
NE of Atlanta
bro, no one is stealing my fuel, no squirrels live in my exhaust and my second tank is not overflowing
the truck is consuming more and running higher egt's
I don't need to burn through 3 tanks to know my fuel consumption and egt's doubled
nj_m715
government's finest
NE of Atlanta
decided to throw parts at it, replaced the turbo boots and resealed the Y pipe
running much better now, normal egt, got 15 mpg on a 200 mile trip
dieselmainiac
