kendawg69a
94 f350 idit leaking oil after I put in a spectre fuel pump. Truck became hard to start when hot so being hopeful I changed out the pump hoping to preserve the I.p...weeks later started leaking oil. also have a coolant leak rotted bottom on radiator that has caused rust to get clogged in the thermostat I believe causing it to over heat and show engine temp light. Have new radiator going in and just picked up new Ford fuel pump but I was wondering if it could be anything else causing this b4 I ruin another 100$ oil change and hopefully save someone else a headache. 120k truck runs great besides a little hot when there's rust in system. did injectors at 100k
