89Laredo
Underemployed
From what Ive read with a new trans you can run Type F OR Dexron. They say Type F will give you a harder shift.
Trans uses dex/mercon fluid.
how long do you think it would take? I've been up since 5 pm.
edit: it's doable. the only problem is my vehicle doesn't run, and i'd have to be there. he doesn't want it getting broken or going missing
Whats wrong with your truck?
Tossed tread on one of my 4 back tires one day when I was going to haul a ton of dog food to a rescue ranch. I also have a tired injection system, has a ear piercing knock with the injectors (suspect it's those). I looked at a local ford 6.9 once (a strange E350 van) and the engine ran like a oiled machine. no ear shattering knock
Did have hard start problems, but I solved that with a typ4 return line kit (check your pm's typ4, unless I pissed you off or something?)
I'm just cobbling together money from odds and ends to get my truck tip top again, then driving lessons
