good ole truck
creighta
Sardinia, OH
1993 (that's 16 years old) 7.3L with 166,000+miles
-5 degrees. Plugged in 10 minutes, started right up.
Why did you plug it in?
84 6.9 in an 87 (that's 24 years old) -5 degrees, NOT plugged in. Started right up.
dieselrunner
BC canada.
Do you think Plugging it in for those ten minutes made any difference?
Ive never noticed block heaters make that big of a difference that quickly.
4x4TruckinGirl
"Cowgirl"
Dixon, MO
-5 here this morning too.... I had my trucka plugged in all night cause I don't have 30 minutes to wait fer it to heat up.... But it always fires up in the afternoon without being plugged in, it was bout 12 yesterday afternoon......
now -50 is CRAZY!!!!!!!!!
hesutton
The Anti-Anderson
Bowling Green, KY
'86 (23 years old)
2 degrees yesterday am:eek:
Double dose of Power Service Fuel Supplement (White jug)::Thumbs Up
No power to plug the sucker up (gee thanks Mr. Ice Storm):mad:
Really tired batteries (slow cranking):rolleyes:
DPS (I just *** fuel, I don't atomize it) injectors:puke:
Good Beru GP's;Sweet
...........and it started with some serious complaining and tons of white smoke!:rotflmao:D But, it did start!
Heath
82F100SWB
Sioux Lookout, Ontario,CA
Some of you guys missed the sarcasm wagon there...
At -50, you better hope you have battery blankets, or you are barely going to have enough juice to run the glow plugs let alone crank anything over that isn't plugged in.
As for plugging in for 10 minutes, that isn't doing ANYTHING for you, except maybe making you feel good. It takes a good 2.5-3 hours for the heater to make any real difference in starting, and about 5 for it to get to the maximum of what it's going to do.
That's why I always plug mine in while it's still good and warm rather than have it on a timer and let it get cold. I am planning on adding a coolant thermostat control system to it though, they work slick, and the plug has a power and heater indicator to boot:
http://www.phillipsandtemro.com/Use...ically_Controlled_Engine_Immersion_Heater.pdf
smokin_stroker00
dover ohio
Alleycat
