If you have your original OE return line caps i'd try to make those work but depends on what shape they are in or if they've been replaced with aftermarket already. Some say the Delphi kits are good but my experience was not good. The straight caps were the correct size internally but the all of the turns were oversized (.010"). They had a looser fit, gave hard starts, leaked, and made the engine rough running. After checking all the inside diameters I saw that all factory OE caps were the same and fit tighter. They've been on for almost 3 years with zero issue.
