QuercusRubra
Hey guys, I have a 7.3 Turbo IDI, and I'm just looking for some clarification on the glow plug system and whether I need a new relay.
My problem is sometimes the glow plugs aren't running when they should, even though the WTS light is on and power is going to the relay. I can tell because if they do come on, I can see the volt meter in the instrument cluster dive down and the headlights dim -- and sometimes that doesn't happen.
I have a switch in the signal wire to the relay, so I can turn it off and not run the glow plugs if I don't want them -- either I'm monkeying with something, or the vehicle is hot. If the glow plugs aren't working, I can usually cycle my switch and fiddle with things and eventually they come on. Also, if the glow plugs don't appear to run, the engine won't start, if they do appear to run, it starts right up.
So, my question is do I need a new relay?
and I'm wondering how this system really works. I've heard mention of a glow plug relay (looks like a starter relay?) and also a glow plug controller... I guess I don't know what that is... are they the same thing? And then, how does the WTS light work? When my plugs don't light, the WTS light does come on for the expected duration and then goes off. If the signal power switch to off, then the WTS light does not light. So just wondering how that thing works and if there's possibly something else I need before I go buy a new relay.
Thanks in advance, and please let me know if any further clarity or information would help answer my questions.
