mankypro
Learning Slowly...
I have several hundred miles on WMO now. Today I noticed a bit of a rough idle with the engine at 210F when on 100% WMO. Maybe it's just this batch. I did filter it down to 1 micron and ran all of it through a Goldenrod. Since I got this batch from several "unknown" sources (automotive shop oil drop-off), it could be that there was something not so good in this tank.
Just seems to run a little less smooth than my last tank. I'm wondering if I hit the bypass on the Goldenrod and some water/antifreeze made it into my barrels. In any case I'm thinking I'm going to heat the oil to 150F and let it settle for a few days - do we think this will make the water/af settle to the bottom of the barrel? The just pull oil 6" from the bottom and drain the last 6" periodically?
