gauge pillars
Mat J
Way down south
Jupiter, FL
I have a 91 f250 and I want to put in the 3 gauge a pillar pod. All I have been able to find is 92-97. Will these work or does it need to be for a 91, if so where can I find one iv been searching?
k_williams1982
'01 Excursion 4x4
Santa Rosa, CA
Here's pics of my two pod in my '85. I used a gauge pod for a Honda Civic. This is a "rough" draft for the time being, but it beats looking at the bottom of the steering column to see what's happening.
Darrin Tosh
IDI Hound
Grand Rapids, Michigan
Yes, the 92 to 97 will work, That is what I used, you just have to do a little trimming on the top and the bottom. There are pics in my sig.
Piece of cake!
jimraelee
Gaston, OR
Yup, I used a 92 version in my 91... dont be a dork like me and cut your under side unless you check fit first. Mine was actually an over the factory mount style...
fastass350
SStock8569
Washougal, Wa
I used that same mount on my 85, I'll try to insert a pic but haven't had much luck with it. Only thing I found was that the cheesy plugs they give you to hold it to your factory pillar trim don't work well (not at all for me) so I drilled three holes and put some stainless button head cap screws in it with nylocs, then drilled a hole below the middle gauge hole so I could access the original screw on the factory pillar trim.
There are a couple of people on here that are making molds for the older body styles like ours if you are patient.
Cheapest place to purchase one online I believe was EGauges or something along those lines.
Chris
