Gauge install ?
alienturtle
Human
Ripon, CA
I purchased myself a set of glowshift gauges for my 89 7.3 have them all installed EGT, Water Temp, Boost on the 3 gauge pod..Im having problems with the water temp gauge. i dont care about the gauges in the dash so what i did was.
went to the #2 cylinder and removed the old temp sensor..purchased an 1/2 to 1/8npt adapter and used Teflon tape to install my sensor that came with the water temp gauge. The W/LB wire that was used for the old gauge is hooked to the white wire of the 2 wire sensor and the black wire is connected to ground. I had the cluster out of the truck so i just found the W/lb wire at the cluster and pulled it out of the connector. Hooked it to the gauge and figured it would be better than running all theses wires all over the place..
the problem im having is when it was 57 degrees out this morning the gauge said it was 170 water temp..and when i drive it..it slowly goes up to 300 and just max's out.
any ideas?
PowerbyFord
Choctaw, Oklahoma
I am guessing these are electric guages? Make sure you have them grounded good. I put a full set of electric guages in my father in laws 56 Dodge panel truck, and they went haywire when power was put to them because of a loose ground.
alienturtle
Human
Ripon, CA
i just realized i took the wire for the overheat warning switch..the engine coolant temp is the other one on the top of the block..boo!
alienturtle
Human
Ripon, CA
Now im just confused..i have 3 sensors to choose from..the
Engine Coolant Temp Sensor 2 wire located by the coolant hose
Coolant Temp Sender 1 wire behind the ac pump
and the Overheat Warning Switch 1 wire near cylinder 2
Which sensor does the factory gauge use..
The factory temp sender is the one in the block on the drivers side. Not the one in the head, which as you noted is the overtemp switch.
redneckaggie
rebel w/o a cause
angleton/stephenville tx
I would much rather run all new wires because my autometer gauges said that if i did not use 14 gauge wire ran directly from the sending unit to the gauge with no splices, it would throw the calibration of the gauge off resulting in incorrect readings and even gauge damage.
RWF350
Columbia MO
Alienturtle, where did you get the triple pod for the '89? Or did you modify a later model? I've been looking high & low.
alienturtle
Human
Ripon, CA
its from the 92-what ever years with the top and bottom cut off..it looks really good..here are some pics. Im working on fiberglassing the other 2 gauges i have.. i actually wrapped it and fiberglassed it just havent cleaned it up and smoothed it out yet..
Chevyboy_0
Mr.SunnyDisposition
Livermore, Ca
Is the Water temp gauge electric or mechanical? if its electric you shouldnt use Teflon tape on it because the sending unit uses the Head/Block as a ground
GRU
fear the chicken legs
fredonia pa
i have the same gauges. i have them mounted in a pod on the dash above the radio facing me. during the day i cant read them at all. not even alittle bit. but boy at night they are beautiful!
crispy74
