Never miss a discussionGet a roundup of the newest threads delivered to your inbox. Enter your email below and pick how often you'd like to hear from us — no account required, and you can unsubscribe any time.Double opt-in — we'll email you to confirm. Unsubscribe any time.
i am haveing a problem with my fuel system. the two wires that go into the top of the fuel filter container are smokeing when my truck is running , if anyone knows anything about please let me know. thanks
The wires are for the fuel heater, the heater is simply a ring around the inside of the canister that the fuel flows thru, you can disconnect it easily and run without it until you get a new one, sounds like it shorted out.
You wont be able to pull the heater itself because it is O ring sealed to the canister but you can just unplug it till the new heater shows up, I have had mine out for about 6 months because I thought I was getting high dp from it, I proved there was no dp so all is back to normal now.
thanks alot whitmore, i have another question for you guys i hooked my truck up to my computer and there where to codes tripped does anyone know what these mean?
P1690 ECM loop over run
P1693 circuit fault dash tachometer
thanks again
