Fuel switching valve issue
Clb
Another old truck
nannyfornia
All the small holley's are 3/8" npt.
Many are just adapting them.
Even in higher horsepower apps.
The mp13 is more suited to run as a single pickup.
crash-harris
Breaker! Breaker!
Chillicothe, OH
jasper, how are folks adapting them? Just a 3/8 to 5/16 barb and 5/16 hose? No one has reported flow problems with the pickup being 5/16" hose feeding a 3/8" (particularly with a Duralift)?
Clb, know if those Holley hydromats will withstand submersion in diesel? Summit does site one way or the other.
Clb
Another old truck
nannyfornia
Dunno yet' everyone shows gasser's in the adds.
Usually by something like this.
Roughly.
Just to give you an idea. If running a single and need it to be like stock, I would cut the pickup higher and just add a piece of 5/16 line.
Remember, the insides of the selector valve are a lot smaller than that.
crash-harris
Breaker! Breaker!
Chillicothe, OH
I should've measured the pets on my FSV when I had it out. I know the source ports are larger than the return perry's, but you're saying the passages themselves within the FSV are smaller? The Walbro MP 12 may indeed be the way to go then.
Correct.
That's how I had a tiny piece of old pickup Clog mine.
The powerstroke guys are hitting over 500 before the selector valve becomes a restriction.
Clb
Another old truck
nannyfornia
Ran 4 tanks thru it so far each went clean to empty;Sweet
Time to hunt down a set of them filter sock dealeo's
The facet feeds a lot better than the 23 yr old 40 k lift pump did.
effing ford gauges....
came home on the empty rear tank, sucking air before I switched it, had to cram 14 gallons into it.
guess I'm doing both tanks soon.:dunno
Clb
Another old truck
nannyfornia
5-6 tanks since then and it will take 17-19 gallons so I guess I'm good.
For now.
chris142
SoCal
Mine acted up a few days ago. Didn't switch tanks but did switch gauges.one thing I did differently was that I switched tanks with the key off. It seems to be working ok since.
I can hear it click when I move the switch.
