Doesn't the 38 gallon rear tank do away with the spare wheel carrier?
yes it does.
no clue about DRW filler neck, but it can always be made.
The fuel sending unit came today, later I may post some pictures if I can figure out how do do it because I am actually new to this forum.yes it does.
[ATyes it does.
always use "go advanced" or "edit post" to post pictures.
and they have this great new invention called "focus"!![]()
The reason why the fuel tank was missing is because one of the previous owners of my truck was carrying a car battery in one of the side tool boxes which leaked, ate a hole though the tool box, through the bed floor and wrecked the rear fuel tank.Vent up on top of the tank clips to the frame, that's likely your mystery line.
There's also a breather line off the rear axle clipped to the frame up on the drivers side.
What do you think about bed flooring (48x16) from LMC truck?Dude! That is crappy..... Some people I tell you...... Cut it out and weld a new piece in there! Atleast water has somewhere to drain?![]()
Where can I get the shower head from for the fuel sending unit?im using a gasser unit,
it had a dead spot, but it worked itself out.
order a shower head. youre gonna need it, the fuel pumps come with a sock style mounted on the fuel pump.
i deleted the gasser electric intank pump and extended it with a showerhead on the bottom.
