What is the output on that thing? What PSI does it go up to when you are at full throttle? I could be wrong, but is that not going to be used as more of a race setup?
race? WMO is a ******* to get the volume up when its below 50f. Were just standing around right now waiting for a parts delivery from napa to put in a by pass between the inline Bosch electric pump we mounted to the frame for a back up pump.
I'll post some numbers tonight on GPh were just about to test
I meant like a sled pull or something like that. Are you saying that you will use this as the "lift pump" and then if it does not work, you will use the inline pump?
