'93 f250HD 7.3l NA/E40D/3:55's with 225's for 3.84 actual gearing (w/ odo correctly re-calibrated for the shorter tires)/DRW conversion/8'W X 9'L enclosed stake body dump weighing in @ 8100 lbs empty.
engine timing set @ 6 degrees ATDC with fuel cetane value range of 38-42.
hauling 1-3 ton regularly and towing 1 ton chipper often.
top speeds of 45 mph and taking off so slow id put granny to sleep most of the time.applying the basic hypermiller tips such as starting out with ease,coasting to stops,bleeding off the hills,steady foot that makes cruise control look outright horrible,etc.
lots of rural driving this combo on what most would consider back,curvy,hilly roads up here in Maine with a max of 1.5 hr trips at a time.most of the time 30-45 min trips with lots of stop and go.
think old horse and buggy copy cat roads.nothing planned like out west.
fuel economy mods so far;
cowl induction with soup bowl removed.
synthetic engine oil.
synthetic blend rear diff oil.
custom single exhaust starting with a free flowing,true custom built Y pipe.not that stock T pipe.
smoothed stake body sides.
electric engine fans.not set to kick on until well after the T-stats full open temp.
mostly hang around 225-235 degrees.no higher than 240.
culvert for tool holder/aero mod above cab.
standard IDI tune up w/ delphi BB codes and IP from U-Haul inventory close out.
at time of this post:
14.46 MPG over the course of 59 tanks.of which most are consecutive fill ups for a VERY accurate true average mile per gallon.would be higher today had i fixed a rear wheel tire issue much sooner than i did.
non of those "high peak" numbers while driving like a car from me.
(snow plowing not included of course.)
http://www.ford-trucks.com/forums/garage.php?do=showfillups&vehicleid=1301
