brockr
I have fuel leaks, leaks, and leaks. replacer all the soft lines, the orings in the fuel bowl, the water seperator valve ect. each time I replace one thing another leak pops up. now it seems to be coming from the oring on the preasure regulator that holds the part that the ridged metal tube comes up into it from under it. It has the screen inside, the piece that is held in by a c-clip. I need the oring that seals that and can't find it!
I think I just want to delete the fuel bowl and mechanical pump all together. What do I need to put a delete and in line filter/ pump (Fasst maybe) How do I get the high presure side if I delete the mechanical pump. I need a parts list of what it would take to do this, and any directions or advice I can get!
97 cc 4x4 114,000 miles
I think I just want to delete the fuel bowl and mechanical pump all together. What do I need to put a delete and in line filter/ pump (Fasst maybe) How do I get the high presure side if I delete the mechanical pump. I need a parts list of what it would take to do this, and any directions or advice I can get!97 cc 4x4 114,000 miles
