fx4wannabe
Ok wrenched on the truck a while this afternoon and here is my conclusion thus far. The turbo feed was leaking from where it goes into the turbo so I took that apart and resealed it all. Being that the the turbo is above the valley pan some of the oil goes in the valley pan the rest goes everywhere else. This leads to the second problem and point of this post. My valley pan is full of fuel and oil. This is what is causing the 2' puddle under the truck. So far best I can tell is I have multiple hard lines leaking. I put all new injectors and return lines on it already so I know its not that. What I am afraid of is that putting in the new injectors and disturbing the hard lines made it so they won't seal up for what ever reason. Everything is good and tight. I have 3 lines at the pump that are wet, one of them being the main feed line from the filter. I have 2 that are wet at the injector. The other thing that I still have yet to figure out is if the pump itself is leaking. So my question is do we have a good source for new hard lines? I am thinking just get all 8 and rule that out. The source I had here in town doesn't have anymore and its $40 a pop to order them last time I checked. Not really sure what all my options are at this point but at least I am getting somewhere.
what's the gain aren't they the same
