Ggg:
"NAPA Gold is the only NAPA to consider. It is made to a certain specification.
WIX, and the lower grade NAPA filters I do not like "
NAPA gold is made by WIX............Yes , WIX does produce filters for many others tho.
There are only a few mfrs that actually make their own filters......
Who do you think makes Motorcraft?
I like Baldwin but they are hard to find locally for the PSD.
Rampy:
"I use NAPA carb or brake cleaner. Just pull the fuel filter & spray the can in the filter housing. Let it sit for a while and drain the housing as best as possible. Spray again (use about 1/3 can each time) and again soak for 10-15 min.
Then I drain & take a papertowel & screwstick & wipe out the inside of the housing as best as possible.
____________________________________________________
Thats interesting as when I removed the filter, the canister was a clean and clear as could be!
NO residue,crystal clear fuel, no signs of "THE BLACK DEATH".....
{injector "O" ring failure}
Mebee the Stanadyne every 1500mi / 2 weeks
is doing it's job!
And YES I have put a drain extension on the tube.
I HATE smelling hot diesel
BTW, Tnose prices are
Thanx!
I see that you also use the term "screwstick"
I'm fond of using "thumbwrech" as well!
Thanx for the input!
