GEEZER
I replaced my fuel filter in my 1990 box van(ex-uhaul) and the water separator drain valve was hard to turn. I took it apart and the valve turns but it's leaking about a drop every 10 seconds when running. Is there an "O" ring in there that is suppose to keep it from leaking? I didn't see one but I may have destroyed it when taking it a part. Is that a special ring or can I find them at NAPA or hardware store if needed? Will that leak bleed off the pressure in my fuel line? I am having a hard time starting it after it sits for a couple of days and I get air out of the Shrader bleeder valve after the engine runs briefly when trying to start and I have to bleed the air out of it And use ether to get it started. Thanks for any help. Did anybody guess I'm a newbie ?
