FSV & fuel gage?
kbenz
kannapolis, NC
Took out my FSV valve. What wires do I need to connect to get it to read the front tank? Thanks
Cubey
Van dweller
I used blue clip on taps and a jumper wire. Worked fine.
Cubey
Van dweller
so I would jump 3 and 4 then correct?
Assuming your wiring matches the diagram, yes. I got that diagram from my Haynes F-series book, as I recall. My E-series older style FSV was the same way as that diagram above, and jumping 3-4 showed the front tank. 4-5 showed the rear.
#1 on the left, #5 on the right.
Hook the yellow with white stripe wire to the darkblue with yellow stripe wire.
Yellow/white goes to the gauge in the dash
Darkblue/yellow goes to the front sending unit.
kbenz
kannapolis, NC
That was it. Thanks
Lance
