Front wheel toe adjustment help
TrustinDustin
Grants Pass Oregon
I apologize if there is already a thread on this topic. Could some one tell me which way to turn the adjusting sleeve to brings wheels towards each other ? Thank you guys
I can't say right off the top of my head. You can see it when you adjust the sleeves. You can also check with a tape measure after turning them a little bit. Don't forget that there's two of those sleeves. One on each side. You'll make the steering wheel off centered by only using one.
TrustinDustin
Grants Pass Oregon
Thank you, i didnt see the second sleeve until i read your reply...i would of been all messed up..after some turns it looks.like turning sleeves clockwise brings wheels pointing in...thanks again friend.
