Front hub problems
Codyp86
Santa Fe, TX
I am trying to get the front hub off and all of the tools that I have used are not working. The axle is a Dana 50 TTB. Any help would be appreciated.
What are you calling the "hub"? The spindle.
Or the 4x4 lockout?
DaveBen
Ukiah, Ca
I call anything on the outside of the spindle the HUB. The spindle is not part of the hub but the "Hub Assy", that has bearings and the Warn Locking Hub is the "HUB".
Macrobb
North Idaho
so... 6 hex bolts, off comes the "hub cover" Behind that, you'll have a loose spring(remove). To get the next piece out, there are two snap rings - one on the end of the axle shaft in the center, and one around the very edge of the aluminum "hub" piece - it's a flat ring that's like 2 full wraps of steel. You have to get one end out with a pick and then just work it around. With that out the "hub" slides out(I usually use two of the hex bolts from the cover to guide it out).
Behind that is a bunch of grease and you can see the outer spindle nut - "key" plate - inner spindle nut. With those three removed, you can pull on the large hub piece(the whole thing that spins) and out it comes.
