Has anyone fixed the sagging front end on the D50. I was thinking of getting some leaf springs and add one to each side has anyone tried this or have any other sugestions.
Probably need axle pivot bushings, there are two bolts, one at the end of each axle beam, that go through a bracket and have a nut on the backside. One you can see from the front, one from the back. There is or should be a bushing there. It is probably worn out. These make a big difference in alignment and front end placement.
James
Our trucks came with 'negative arch' springs up front. They aren't arched the wrong way, but they do weaken over time. Best if you check your front end completely though before you stiffen it up with add a leafs.
James
I've done both. I've got one truck with airbags almost exactly like the ones Zigg shows and another truck with the Tuff Country add-a-leafs. I haven't decided which I like better yet (add-a-leafs are only 4 weeks old). I think if your truck is completely stock and you just want to raise the front, add-a-leafs are the easiest and most cost effective. If you have a heavy aftermarket bumper or snow plow, then bags are the way to go. I don't notice much difference ride wise. Remember if you are going to the trouble of getting the sag out, then new shocks are in order also. Kinda like the "lift and separate" bra deal.
bags would suck with a twin I beam front axle. if they weren't exactly the same, alignment would suffer. with a D60, if they were off a tad it would just look like the truck was going down the road crooked.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
