front axle problem.
wanabebig
Anthony, ks
as the states i have a front axle problem, and was wondering if y'all could help out. where the axle shaft goes into the outter knuckle on the passenger side somethings out and i'm not for sure what, because the axle shaft can just flop around. what could have gone bad to make that do that?
Goofyexponent
Mentally Unstable..
Halifax / Nova Scotia
The 3rd bearing that the axle rides on as it goes into the spindle is shot.
I will try and dig up a part number.
I had the SAME problem on a D44'd F150.
wanabebig
Anthony, ks
alright, how would you go about fixing that? do you have to take the hub and everything off to get it? or is there another way to get to it?
Goofyexponent
Mentally Unstable..
You got to pull the tire, caliper, rotor, locking hub, axle lock ring, spindle and then yank the axle out. It sounds like a lot of work, but it's pretty straight forward!
wanabebig
Anthony, ks
alright, sounds pretty simple. thanks man! kinda went to the dark side with this truck, but it was cheap and it'll make a good seller when i'm done fixing a few things.. then its back to my idi's. ha!
Goofyexponent
Mentally Unstable..
Dana 44!!!
Bearing Only!!
TIMKEN Part # B2110
NATIONAL Part # B2110
SKF Part # B2110
Complete bearing and seal kit!!!
NATIONAL Part # SBK1
Goofyexponent
Mentally Unstable..
I would assume that because your truck is a super cab, that it has a 50. It very well could have a 44. Crawl under, and look on the side of the pot and see if it has 44 or 50 casted in. You may already know what front end it has under it.
wanabebig
Anthony, ks
well this is actually for a newer one that i got which is a 1999 not for my 84, but it is a super cab super duty
Double-S-Diesel
parts seller
derry pa
99 SD changes every thing
but the problem is still that bearing, just a different repair procedure
Goofyexponent
Mentally Unstable..
Whoops! I was just goin by the truck in your signature!
I haven't had a new truck apart before, But I think it's something like a newer car's front end. Unit style bearings and nothing like the old school stuff I am running.
82F100SWB
Sioux Lookout, Ontario,CA
You can replace that bearing in a Super Duty unit bearing, I did on my 00. Hope the hub seal that goes in the knuckle behind the bearing is in good shape. Also, hope that the stub axle isn't toasted form floating around like that.
Goofyexponent
Mentally Unstable..
I would assume that the removal procedure is.....outer axle nut, tire, cliper, rotor, bolts holding the unit bearing on and THEN the axle.
That's how I did the wheel bearing on Vicki's car, and I assume that the unit bearings on a new style Ford SD are SIMILAR, maybe not the same.
Someone PLEASE fill me in and do NOT be afraid to correct me!!
Double-S-Diesel
parts seller
derry pa
on the SD ya pull the lock out hub, then the snap ring, caliper and rotor, undo the abs wire to the inner fender, then 4 nuts on the backside.
pretty simple unless the hub is stuck to the nuckle, then itsa pia
I also pop the tie rod off so I can turn the knuckle by itself.
dogdanblue
