found a rearend for the 1983 I think?
farmerscotty
guy called me with an 88 f250 rearend he is coming my way in a week and could bring it closer to me......... he is over 150 miles away. Question is this........will it being a Dana 60 be the same one? or will the spring support brackets need to be removed and rewelded? Anyone know what years will direct bolt to a 83? Thanks
Scott
#2 rearend in less than a year! this is getting old!
oh yeah it is a 3.55 gear ratio..
MUDKICKR
NITRO WV 25143
oh yea my trk has a 85 f-350 frame, 85 f-350 dana 50 ttb frt end,89 f250 diesel frt springs, 85 f-350 rear springs, 92 f-250 sterling 10.25 rear axle, the body on my trk is an 92 f-250 so to use the speedo i needed the rearend,(rather have the 10.25 then the factory dana60 anyways) a 92 460 shortblock, 76 460 heads (carb engine now) 78 bronco c6 auto, 84 f-250 208 transfer case, i guess what im trying to say is ford WILL interchange a lot of parts, and you shouldnt have any problems switching rearends, unless its out of a cab and chassis trk, which if its an f-250 i wouldnt think that would be an issue, also i have an 89 f-250 diesel and it also has a 10.25 sterling axle in it. might want to make sure that is what he is bringing you, cause if it has a speed sensor in the top its the sterling
farmerscotty
cannot rebuild one I have.........axle tube is ruined.........axle came out with 2 round bales on flatbed.........crowbarred the end of axle tube......ugh!
for 100 bucks I cannot go wrong.
It will bolt right up, but won't be as stoudt as your Dana 70 was.
MUDKICKR
NITRO WV 25143
what do you haul to make it do that? my trk has 37" tires and i like the burnouts but it hasnt gave me a minutes trouble (but i did rebuild it though) anyways if it did that to a dana 70 why not go with one out of a 1 1/2 of even a five ton. i know it would be overkill but at least you know you wouldnt break it
Bo17
